Problem downloading plugins
Help for Audacity on macOS.
new Aud user
Post by new Aud user » Fri Apr 10, 2020 1:51 am
With OS Catalina when I download a plugin from "https://wiki.audacityteam.org/wiki/Down ... s#download" I get a text file. I did this years ago but now I cannot seem to get the hang of it. I would appreciate any direction offered. Thank you.
Re: Problem downloading plugins
Post by steve » Fri Apr 10, 2020 12:31 pm
"Nyquist plug-in" are just text files, but with a file extension (the part of the file name after the dot) of ".ny" rather than ".txt".
Unfortunately, Safari has a habit of adding ".txt" to the end of the file name.
Fortunately the "Nyquist Plug-in Installer" can fix that automatically.
See: https://manual.audacityteam.org/man/nyq ... aller.html
