Catalina
Help for Audacity on macOS.
new Aud user
Catalina
Post by new Aud user » Sat Mar 07, 2020 6:46 pm
From what I have read in this forum, if I try to use Audacity in OS Catalina it is 50/50 as to whether or not I will have problems. Am I correct? Thank you.
Re: Catalina
Post by steve » Sat Mar 07, 2020 6:55 pm
That mostly depends on how well you can follow instructions: viewtopic.php?f=47&t=107162
new Aud user
Re: Catalina
Post by new Aud user » Fri Apr 10, 2020 2:31 am
Thank you. I followed the directions. Audacity opened but Terminal did not ask for the correct permissions.
Re: Catalina
Post by steve » Fri Apr 10, 2020 9:37 am
If the Terminal already has the necessary permissions, it won't ask again.
What happened? Did Audacity launch? If it did, then what happened when you tried to record?
new Aud user
Re: Catalina
Post by new Aud user » Fri Apr 10, 2020 6:07 pm
I am unfamiliar with Terminal so perhaps I goofed but I pasted "open /Applications/Audacity.app/Contents/MacOS/Audacity" into Terminal and then hit enter and then Audacity v.2.3.3 opened. I do not use Record but I still would like to use Audacity for all its other functionality since I have been doing so for years. I started to edit an imported sound file and that is as far as I've gone.
Re: Catalina
Post by steve » Fri Apr 10, 2020 6:45 pm
That's it :) That's exactly what should happen.
If you try to record, then you may be prompted to give permission for the microphone.
As you don't need to record, there is a more convenient option, but as Audacity 2.4.0 is scheduled for release near the beginning of March, I'd suggest that you just carry on as you are until 2.4.0 is available.
new Aud user
Re: Catalina
Post by new Aud user » Fri Apr 10, 2020 7:49 pm
Thank you so much. I have figured out how to use Audacity well enough for my purposes so I am anxious to carry on under Catalina and will look out for the next version.
new Aud user
Re: Catalina
Post by new Aud user » Sat Apr 11, 2020 5:19 pm
The first sound file I imported from my hard drive in AIFF format sounds distorted in Audacity. I imported it again in a new window and the result is the same. As a check, I played the same file in Music and it sounds fine. Do I need to wait for Audacity 2.4.0?
UPDATE: I am stubborn so I launched A. from Terminal again and imported the same file as yesterday and it sounded fine. I opened a new window and imported a different AIFF file and it too sounded fine so hopefully I just had a glitch.
OOPS: same problem is back- sound in A.is distorted but OK in Music.
