Projects not opening in Catalina
Having an insane time trying to post to this forum. Going to post this and then edit
Using 2.3.3 with Catalina Terminalworkaround. Can record, edit and export without issue. When I try to reopen projects it isn't working. They bounce for a second and then fail. Got one to open once by dragging project directly onto dock icon but hasn't worked again.
If I open without the Terminal workaround then the projects open but then the audio files aren't recognized in the timeline.
Thoughts?
I'm running
10.15.2 (19C57)
iMac (27-inch, Late 2013)
3.2 GHz Quad-Core Intel Core i5
16 GB 1600 MHz DDR3
Thoughts?
I'm running
10.15.2 (19C57)
16 GB 1600 MHz DDR3
Re: Projects not opening in Catalina
Do you have all the pieces of the project available? Audacity Projects are not one single file. They are a Project Manager (aup) file and a _data folder with the actual sound.
Do you have both parts in the same location or folder? Do the shows open if you just double click the aup file.
Did you try to change the name of either the aup file or the _data folder?
Sorry. Got caught up in a project.
I haven't changed a thing about the file placement or the project names. Still having this issue. If I open a new project I can record, edit and export. Once the project is closed and saved it's done...
Oh wait... if I actually open from the FILE -> OPEN dialog it does open... But clicking or dragging doesn't work no matter what...
Case partially solved?
Audacity doesn't support clicking and dragging of project files, though by default, "double click" on an AUP file should open the project in Audacity.
Universalis
Audacity 2.3.3 on Catalina 10.15.3:
I can confirm that double-clicking on AUP files either does not open them at all or opens them with label positions displayed but audio flatlined and inaudible.
Opening the AUP file with File > Open does work.
Double-clicking the AUP file when Audacity is not already running also works.
Double-clicking on AUP files won't work with current or past versions of Audacity on Catalina due to this issue: https://www.audacityteam.org/download/mac/#sysreq
The next Audacity release will (hopefully) be fully supported by Catalina.
Universalis
That is splendid news. I will look forward to announcements about the availability of 2.4.0.
odododododod
One work around I use is to quit Audacity, then double click the project icon again. It's the most useful for me at the moment.
Hope this is useful for someone.
jareality
I just installed the latest Audacity version, v2.4.1, and I'm still having this same issue where double clicking an audio file or selecting "open with" doesn't work if Audacity is already opened (on Catalina). Does 2.4.1 fully support Catalina? Or is this something else altogether?
I'm not sure what is preventing projects opening when double clicking on the AUP file while Audacity is running - it is being looked into.
Note that associating audio files with Audacity has never been an official supported feature, even though it has previously been possible on all platforms.
