Audacity Error Log
Help for Audacity on macOS.
The Gigmeister
Audacity Error Log
Post by The Gigmeister » Sat Nov 30, 2019 6:25 pm
I am using the most recent 2.3.3 version of Audacity on my mid 2010 iMac running High Sierra. I got a copy of Izotope Elements 8 and installed it yesterday. Then I upgraded to version 9 of Elements and un installed version 8 after loading it as a plug in on Audacity. Now the system gives me this error message every time I try to run Audacity. It won't open and I have to force quit the program. I have even un installed and re installed the software twice. Is there something I can do to fix this? Thanks in advance.
Screen Shot 2019-11-28 at 8.37.11 PM.png (140.01 KiB) Viewed 294 times
