catalina
Help for Audacity on macOS.
Bob_Vinyl
catalina
Post by Bob_Vinyl » Fri Nov 29, 2019 2:29 pm
Hello, I'm Bob & newbie in this forum...
Working with Audacity for digitalizing my vinyls.
Upgrade to Catalina.
Upgrade to Audacity 2.3.2
Using workaround...
Worked very well.
Upgrade to Audacity 2.3.3
Workaround stopped working
I've send an email about that problem to the Audacity team.
Then I made an Audacity User account, this account using now.
"Downgrade" to Audacity 2.3.2
It worked again.....
That's all.
