Recording through 2 channels
Help for Audacity on macOS.
Jaybelam
Operating System: macOS 10.14 Mojave
Post by Jaybelam » Wed Nov 27, 2019 7:28 pm
Good evening,
I'd be very grateful for some help please, I have been trying to find a solution for ages but have run out of ideas....
I have the focusrite Scarlett 2i2 and a macbook pro with macOS Mojave.
No matter what I do I cannot record through 2 channels, on the audacity screen I have 'core audio' selected, scarlett selected in both the recording device and output device and 2 (stereo) recording selected. I have followed all the settings in the audacity help section but nothing has worked.
I have no idea what else to try, any help would be greatly appreciated.
Many thanks, Jay
