MacOS 10.15.1
MacOS 10.15.1
I note that there is a warning about functionality with Catalina. I waited until Catalina was updated to 10.15.1 because there was a problem with the initial upgrade. I haven't used Audacity yet but I have been able to open it and will report further in due course.
