Audacity & apple new update
Hi,
So I have done the same steps in opening audacity via the terminal but:
1) do I have to always paste the link/code line ---- open /Applications/Audacity.app/Contents/MacOS/Audacity ---
into the terminal?
2) the microphone is ticked with audacity and terminal but still no recording?!
It recorded before then everything stopped?
Many thanks in advance
into the terminal?
Re: Audacity & apple new update
Someone reported that they were able to create a "Desktop alias" to the command: viewtopic.php?p=378549#p378549
What's happening? A "flat line" recording?
What are you trying to record, and what equipment are you using?
Hi Steve,
Yes, it shows flat line and I am just making podstcasts using Rode podcaster mic
audacity doesn't open even if I paste open /Applications/Audacity.app/Contents/MacOS/Audacity into terminal
I'm confused. How did you launch Audacity for your first post in this thread?
Hi Steve,
first, I read the first ticket here on how to open which was via terminal and pasting the code to open and then ticked the privacy settings for the future. I then shut down my mac and when I turned it next time, I repeated the same steps but it keeps giving me a flat line and doesn't record.
I am not sure what have I done wrong and if there is a video to follow, it would be gratefully appreciated!
Best
Best
So does Audacity run, or not?ibojan wrote: ↑Wed Nov 27, 2019 3:18 pmfirst, I read the first ticket here on how to open which was via terminal and pasting the code to open and then ticked the privacy settings for the future. I then shut down my mac and when I turned it next time, I repeated the same steps but it keeps giving me a flat line and doesn't record.
