Locking up
Help for Audacity on macOS.
[email protected]
Re: Locking up
Post by [email protected] » Sun Sep 29, 2019 12:10 pm
kozikowski wrote:
Sun Sep 29, 2019 2:40 am
Memory Leak? Every time Audacity loops through a file it leaves a tiny part of itself in memory.
Go > Utilities > Activity Monitor.
CPU, MEMORY and DISK are semi-real time displays and you can watch the progress of your jobs and how many resources are being used. It's possible you're going to find something slowly filling up or in some other way advancing over time, eventually failing.
Solved it. In Library/Applocation Support/audacity there is a session file, deleted that and the app starts up now.
