Macro Export destination
[email protected]
Is there a way to state where I want the files stored?
Re: Macro Export destination
When Batch processing, the exported files are placed in a "macro-output" folder in the same directory as the selected files. There are no other options for normal Macros.
See also: viewtopic.php?p=377574#p377574
[email protected]
Thanks.
Off-topic question:
I have preferences set up to notify me by email if someone responds to a topic, but I've never received a notification. Any suggestions?
Off-topic question:
Click on the "spanner" icon at the bottom of a page, then click on "Subscribe to topic" to toggle that option. (for some mysterious reason, "not ticked" means that you are subscribed to the topic and will be notified of replies).[email protected] wrote: ↑Wed Sep 25, 2019 12:21 amI have preferences set up to notify me by email if someone responds to a topic, but I've never received a notification. Any suggestions?
[email protected]
Thanks. I had assumed I was automatically subscripted to topics I created, especially seeing the check next to subscribed.
Yes, that's a bit weird. I don't know why it's done like that, but we don't make the forum software, and there does not appear to be any practical way to change that.
[email protected]
I am still not receiving notifications. Any other settings?
You could check in:
User control panel (click on your name near top right corner of page) > Overview > Manage Subscriptions
[email protected]
