Macro export?
Help for Audacity on macOS.
[email protected]
Macro export?
Post by [email protected] » Mon Sep 23, 2019 5:38 pm
Mac OS: 10.13.6
Audacity: 2.3.2
I have a macro to normalize my audio files. I would prefer to keep them in the same format as they are currently in (varies by file). The current steps that I have are:
01 - Normalize
02 - End
I am guessing I need an Export step as well (first time trying macro mode)? But I cannot find an export that will maintain the existing file format. For that matter it seems like the only exports are FLAC, MP3, MP3 56k (before and after), OOG, and WAV. No AAC, M4A, etc.
Re: Macro export?
Post by steve » Mon Sep 23, 2019 10:25 pm
Macros currently only offer a limited selection of file formats for export. However, if you export as WAV, then you could run a third party format converter to batch convert the files to the format that you require. (Additional export formats are likely to be added in the future).
[email protected]
Re: Macro export?
Post by [email protected] » Tue Sep 24, 2019 6:28 pm
Thanks, but I wanted to retain them in their original format, so a third party app really doesn't help.
Re: Macro export?
Post by steve » Tue Sep 24, 2019 7:29 pm
Macros are deliberately very simple - they provide a single list of commands, and that's it. Macros are not able to handle "conditional" commands. You can't tell a Macro: "IF it's an MP3, THEN export as MP3, ELSE IF it's a WAV, THEN export as WAV..."
If you need to use conditional commands, you need to use a more powerful scripting language than a normal Macro. Audacity provides two such options, but both are significantly more complex (and more powerful) than Macros. The options are:
[email protected]
Re: Macro export?
Post by [email protected] » Wed Sep 25, 2019 12:22 am
Thanks will look into them later.
