automatically addding spaces between clippings
Help for Audacity on macOS.
maximoff
Post by maximoff » Sun Sep 22, 2019 5:12 am
Hello:
I have a bunch of files, each one consists of short sound clippings (verb conjugations). I want the silence parts between the clippings be exactly .75 seconds. How do I do it automatically?,
Many thanks,
Eugene
Trebor
Re: automatically addding spaces between clippings
Post by Trebor » Sun Sep 22, 2019 5:29 am
I have a bunch of files, ...
If there is already silence* ≥ 0.75 seconds, truncate silence to 0.75 seconds.
To batch process many files in the same way use Audacity macro.
[ * silence is any sound below a user-defined threshold, not necessarily zero flatline ]
maximoff
Post by maximoff » Sun Sep 22, 2019 6:31 am
Many thanks!
