Trouble no signal
Help for Audacity on macOS.
PatrickDegryse
Trouble no signal
Post by PatrickDegryse » Fri Sep 13, 2019 10:16 am
Imac with 10.13.3
Serato pro
Audacity 2.3.2
Pioneer ddj-sz
Hi all, i am trying to record but don’t get any soundsignal in audacity, except for microphone... If i choose Pioneer ddj nothing
Imac has Lacie 4gb connected and Pioneer connected with Usb to Imac
I am not an IT guy so please keep it simple
Btw: with the old DDJ-RX never had a problem.
What’s wrong? (Screenshots of all settings would be welcome if someone has a solution)
Thx Patrick
