Recovered Audio Looping In Intervals
Help for Audacity on macOS.
valiant
Post by valiant » Mon Sep 09, 2019 9:49 pm
Hello hello.
I was able to use Audacity to recover some 48k/16bit WAV files that had been corrupted during recording on a Zoom H6N. We were recording two channels.
I recovered it with the following settings...
Signed 16-Bit PCM
Little Endian
1 Channel (Mono)
Start Offset 0
Amount 100%
Sample Rate 48000
However, the recovered audio seems to be looping - it goes from roughly one second of one microphone to one second of the other microphone - and this is repeated throughout the entire 20+ minute interview, all on one track.
My question is - is there any way to automate a process that can split up this one file into its original channels? Something that would cut at an exact interval, paste to a new track, etc. etc - so that I can have the two different microphone seperated.
Thank you so much for your help. I'm on Mojave 10.14.3
