wireless speaker playback 10.11.16/ 2.2.2
Help for Audacity on macOS.
joek
Post by joek » Fri Aug 30, 2019 8:08 am
Hi,
I am considering getting a wireless/bluetooth speaker (e.g. Sonos) to use with my macbook, but not sure how everything would work with that. may be a stupid question but would i be able to play recordings made with Audacity in this way, i mean directly from Audacity itself rather than from an mp3 generated from an Audacity file? and how would this work?
thanks.
Re: wireless speaker playback 10.11.16/ 2.2.2
Post by steve » Fri Aug 30, 2019 8:14 am
I would highly recommend using wired speakers (or wired headphones) with Audacity. Lots of people have trouble using bluetooth speaker with Audacity due to the way that wireless audio is implemented.
