Slow Performance on 6 Core Mac Pro
Help for Audacity on macOS.
RodentiaPuppy
Operating System: macOS 10.14 Mojave
Re: Slow Performance on 6 Core Mac Pro
Post by RodentiaPuppy » Tue Aug 25, 2020 4:47 am
I know this is an odd question to ask, but what is your audio buffer length in Audacity? I've had issues with a low frame rate for the entire interface until I changed the audio buffer length as below:
Audacity buffer length.png (976.64 KiB) Viewed 140 times
My default was 100ms which limited the refresh of the interface to 10fps, so I've changed it to 33ms for 30fps. This sped up the interface all around.
RodentiaPuppy
Post by RodentiaPuppy » Wed Aug 26, 2020 12:12 am
I forgot to mention I did this on Audacity 2.4.2 though I think this may work on 2.3.x and 2.2.x as well.
