Slow Performance on 6 Core Mac Pro
Help for Audacity on macOS.
MotM
Re: Slow Performance on 6 Core Mac Pro
Post by MotM » Sun May 31, 2020 2:57 pm
Also, the Mac page shows 2.4.1 as the latest release on 20 May. Is 2.4.2 now available?
Post by steve » Sun May 31, 2020 4:34 pm
Oops sorry, the sun must be getting to me :oops: .
I'm using Audacity 2.4.2, but it's a pre-release version just for testing. The release version is 2.4.1, and that is the correct version that you should be using.
Apologies for creating confusion.
A "fix" was implemented around 10th May, so I think that fix should be in Audacity 2.4.1.
The problem appears to be due to a change in the Apple SDK which makes display repaints much slower. The Audacity developers have tried to work around the problem code. I would have expected 2.4.1 to be noticeably less laggy than 1.3.3. Is that not the case?
MotM
Post by MotM » Sun May 31, 2020 5:22 pm
Ahh, OK! I was afraid I might not have seen it. :D
I haven't tried 2.4.1 but based on Masterl1nk's comment earlier, it looks like the issue remains in 2.4.1. The performance on my machine is the same as what his video shows.
MotM
Post by MotM » Sun May 31, 2020 7:04 pm
Installed 2.4.1 and the very laggy performance is still there, consistent with Masterl1nk's observations. Did a clean reboot with Audacity as the first program open, etc. No change.
JeffW
Post by JeffW » Sat Jun 06, 2020 11:19 pm
yes, the issue remains there. I have IOS Catalina. People posted a lot on this topic, but no clue yet, except for an advice to shrink the browser size to 1/4. It works a bit for my computer.
seanjs
Post by seanjs » Thu Jun 25, 2020 6:13 am
Same issue here (Catalina running on a Macbook Pro 16") and, incidentally, it's causing some minor recording skipping as well.
I've found that changing my screen resolution to a lower setting improves the issue, although it's still pretty bad. It's not a great solution, but it beats working in a tiny window.
If I run Audacity in Windows using Parallels there is no issue with editing audio. I haven't tried recording that way.
I had no problems on my 2015 12" MacBook. Strange that an 8-core beefy machine with an awesome graphics card can't handle it. I saw in the documentation about recording skipping it saying something about high resolution monitors and redrawing the screen causing issue, and the solution is to shrink the window.
Post by kozikowski » Thu Jun 25, 2020 9:35 am
I believe most of that beef is loafing. It used to be the case that Audacity is only running on one of the cores.
billw58
Post by billw58 » Sat Jun 27, 2020 4:27 pm
To everyone who has reported problems on this thread ...
Please go to Apple menu > About this Mac then click "System Report". In the system report, under Hardware, click on "Graphics/Displays".
What do you see for "Framebuffer Depth"?
-- Bill
billw58
Post by billw58 » Sat Jun 27, 2020 4:32 pm
There is a workaround that will make Audacity snappy again on 30-bit displays.
Right-click on the Audacity.app icon and choose "Get Info". In the Get Info window, check "Open in low resolution".
The GUI might look a bit fuzzy in places but Audacity will be "snappy" again.
-- Bill
MotM
Post by MotM » Sat Jun 27, 2020 5:00 pm
Thanks Bill! My 5K iMac is also 30-Bit as is my second screen. I tried the trick to open in low resolution and while it's not "normal" levels of snappy performance, it looks very usable. I have a multi-hour edit job today and will see how it goes.
Thank you for the work-around!
