Slow Performance on 6 Core Mac Pro
Re: Slow Performance on 6 Core Mac Pro
Mac OS handles it and appears to scale the menus to usable levels. I'm not aware of an option to adjust this (other than through Accessibility panel) and it didn't change between 2.3.0 and 2.3.2.
Hi
I'm having exactly the same issue with the following:
iMac Retina 5K 27 inch 2019
3,6 GHz Intel i9 8 cores
RAM: 32 Go 2667 MHz DDR4
Video: Radeon Pro 580X 8 Go
running Catalina 10.15.2
using Audacity 2.3.3
Also still struggling with it here. I moved to Catalina and having the same issues with 2.3.3. OS level had no impact (positive or negative) on the performance.
Username00
Hey!
I am having exactly the same problem with my Audacity. I am using Mac OS Catalina. Resizing window keeps lagging. Same as selecting parts of the wave.
Anyone found any solution for this?
Unfortunately still the case here as well.
Returning to Audacity after a bit of break from DJing and notice exactly the same terrible lagging when using anything other than a small window.
iMac 5K, 27", late 2015. 10.15.6 (Mojave), i5 3.2GHz, 16GB RAM
Audacity 2.3.3
Audacity 2.3.3
Does that also have a high dpi display?
Masterl1nk
Hi all! I'm also having this performance issue. No external monitors connected
Laptop:
MacBook Pro (13-inch, 2019, Four Thunderbolt 3 ports)
2,4 GHz Quad-Core Intel Core i5
16 GB 2133 MHz LPDDR3
Intel Iris Plus Graphics 655 1536 MB
Built-in Display
13,3-inch (2560 x 1600)
Intel Iris Plus Graphics 655 1536 MB graphics
macOS Catalina 10.15.4 (19E287)
Audacity 2.4.1 (also tested 2.3.3)
I have the same very noticeable lag when using Audacity in full screen / big window, not happening on a small window. Did a short screen record that shows the problem,
https://www.youtube.com/watch?v=2KfDVXzTAdM
Thanks in advance
Laptop:
Built-in Display
Thanks in advance
The current version of Audacity is 2.4.2. Updating is highly recommended as this is a bug fix release. https://www.audacityteam.org/download/mac/
Steve, do you know if 2.4.2 addresses this issue?
