Random crackling only through bluetooth headsets
Help for Audacity on macOS.
mcp111
Re: Random crackling only through bluetooth headsets
Post by mcp111 » Fri Nov 20, 2020 5:38 pm
Is this what you're asking? Right now it's not hooked up, but I'm using a mic preamp input and then the output shows the IP 300 speakers when hooked up.
Screen Shot 2020-11-20 at 12.35.52 PM.png (196.36 KiB) Viewed 126 times
Post by kozikowski » Fri Nov 20, 2020 6:06 pm
Missed one. Does the recording input stay where you put it when you do connect the Bluetooth system? Like connect the two devices you mentioned and see what happens. You may need to restart Audacity or Transport > Rescan.
jademan
Forum Crew
Post by jademan » Tue Nov 24, 2020 2:46 pm
Under Edit > Preferences > Devices, have you tried reducing your buffer length to 20ms ?
See also: viewtopic.php?p=352024#p352024
