Need help with manual uninstall
Help for Audacity on macOS.
WRR
Post by WRR » Mon May 13, 2019 1:33 pm
I am attempting to manually uninstall Audacity and do a reinstall.
In doing so, I have located/moved 1 Audacity item file from Application Support to trash......and 2 Audacity files from Preferences to trash.
When I attempt to empty the 3 files in trash, 1 file remains in trash with this message:
The operation can't be completed because the item
"org.audacityteam.audacity.plst" is in use.
Thanks in advance for any and all help!!
Re: Need help with manual uninstall
Post by steve » Wed May 15, 2019 3:35 pm
Try shutting down all applications, then shut down the computer and reboot.
