Lame not working
Help for Audacity on macOS.
useydess
Lame not working
Post by useydess » Tue Apr 02, 2019 7:53 pm
hello i am a audacity user and i am having trouble with installing LAME onto audacity. when i download it and such it works but when it locates the file it locates as a libmp3lame.dylib and not a libmp3lame64bit.dylib. and when i do find it it does nothing
billw58
Re: Lame not working
Post by billw58 » Tue Apr 02, 2019 9:36 pm
Which version of Audacity are you using? The 64-bit version of LAME is only for version 2.3.1.
-- Bill
