2.3.0 bugs not fixed
Help for Audacity on macOS.
jarome
Post by jarome » Tue Mar 19, 2019 6:50 pm
The most annoying bug of all-- the inability of pop-up boxes to accept keyboard input to select OK--is still there in 2.3.1.
With a selection with a gazillion tracks, of you hit cancel instead of OK on the rename box, you must start all over again!
