Gestures not working. Pinch zoom, 2 finger scroll [SOLVED]
CipherCode
Hi all. I am having trouble. I just bought a 2018 MacBook after running a 2014 for the last few years. Same OS (Mojave). Audacity 2.1.1 - On the new MacBook, none of the finger gestures are working. I had come to rely on pinch zoom on tracks, and 2 finger left and right scrolling. Anyone else run into this issue?
billw58
Re: Gestures not working. Pinch zoom, 2 finger scroll
Pinch-to-zoom works fine on version 2.3.0 on my Macbook Air 2018. Suggest that you upgrade.
-- Bill
-- Bill
I don't think gestures are supported in Audacity 2.1.1.
Audacity 2.3.0 is available via the Audacity website: https://www.audacityteam.org/download/mac/
CipherCode
Re: Gestures not working. Pinch zoom, 2 finger scroll [SOLVED]
Well, I feel stupid. I have no idea how I put such an old version on my mac when I reloaded. I blame bourbon. Thanks to you both.
