I like the second recording better as well. I have both Macro's installed now and will play with the DeEsser.ny plugin using the defaults. Thank you for all your help on this. We will desssssstroy this evil SSSSSS and TTTTT!kozikowski wrote: ↑Mon Mar 11, 2019 3:30 amNumber One is Audiobook Mastering and no EQ. One has "SS" sounds that will drill wood and fog glass.
Two is the same clip with DeEsser carefully applied and tuned. Someone posted the DeEsser defaults could use work. They're right.
Three is the same clip with 6300Hz-24dB applied.
Two has a pleasant balance between the SS sounds and the rest of the voice tones.
Three has the same problem DeCrisper1 has. It muffles everything down but leaves the haystack and slightly piercing SS sounds.
-Ron
