Audacity says another copy is running [SOLVED]
Help for Audacity on macOS.
johnro43
Post by johnro43 » Sat Feb 09, 2019 11:41 pm
I am getting a message that 'another copy of Audacity is running' when I try to initiate the program. Force Quit shows no Audacity. I deleted the software and re-downloaded. Still get the same message. "Audacity" appears on top line of Desktop, with no commands.
I had a minor mishap ... foot in headphone cord ... moved computer and disconnected the off board drive I use for .aup files. Don't think that would cause this. Any ideas?
Desktop
Screen Shot 2019-02-09 at 5.39.38 PM.png (330.45 KiB) Viewed 221 times
Re: Audacity says another copy is running
Post by steve » Sun Feb 10, 2019 12:14 am
Try rebooting the computer.
If that doesn't fix it:
  1. Click on the "Go" menu, and choose "Go to Folder"
  2. Copy and paste this location: ~/Library/Application Support/audacity/
  3. Look in the SessionData folder and trash any file you find there.
johnro43
Re: Audacity says another copy is running [SOLVED]
Post by johnro43 » Sun Feb 10, 2019 3:04 am
I had tried reboot ... your second solution was OUTstanding. I probably should have figured that out myself BUT having an expert answer makes it much less nerve-racking to push that purge button
Thanks
