Hello!
I am trying to insert a song into a playlist, which means all the other songs on the playlist need to shift right.
New to Audacity and mixing. Appreciate any help you can offer.
Hello!
Thanks - how do I select multiple tracks at once??
To select all tracks, “Command + a”
(You can also click and drag across multiple tracks)
I’m actually NOT trying to align them end to end… I have already done work with layering the tracks, so if I align them end to end, I will loose that work.
I’m trying to insert a track, move the other tracks to the right, but keep the work I’ve already completed ‘locked’ in place.
Thanks for your help. I really appreciate it.
How do I select multiple tracks to move - not all tracks, just most??
Got it!! Thank you so much!!!
