2.3 not monitoring USB input with Mojave
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
RS25
Post by RS25 » Fri Dec 07, 2018 12:44 am
I just installed 2.3 on my MAC running Mojave and tried to record from USB input and I'm getting nothing on the input monitor. I was able to monitor/record on my wife's MAC suing the same device. (On hers 10.13 OS and 2.1.? I think)
Re: 2.3 not monitoring USB input with Mojave
Post by steve » Fri Dec 07, 2018 1:56 am
Have you given Audacity permission to use recording devices? (see: viewtopic.php?p=357189#p357189)
