Help required
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
anniekikizaza
Help required
Post by anniekikizaza » Sun Dec 02, 2018 3:56 pm
Please may i ask for some help.
I am on Macbook pro version 10.13.6 High Sierra. I was given a audacity USB record player and am trying to download the Audacity drive but i keep getting this message: You can’t open the application “Audacity” because PowerPC applications are no longer supported.
Apple have advised i contact the makers for an updated driver to suit my system but where do you go to get this?
Many thanks,
Re: Help required
Post by steve » Sun Dec 02, 2018 4:01 pm
You must have an ancient version of Audacity as we have not produced a PowerPC version in many years.
The current version of Audacity is 2.3.0 and is available via the Audacity website: https://www.audacityteam.org/download/
You may still get a nag screen from macOS because Audacity 2.3.0 is a 32-bit application, but you can safely ignore that warning. A 64-bit version is scheduled for release in January.
