Japanese: Sliding Time Stretch not working in Audacity 2.3.0
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
Kaudacity
Post by Kaudacity » Sat Dec 01, 2018 2:40 pm
Hello. Mr.eveloper. I am a Japanese heavy user of audacity(mac). I love Audacity.
In ver.2.3.0 is can no longer change the slide / pitch of the time axis(時間軸のスライド/ピッチの変更)?
I used it a lot and was making songs. Please revive the slide / pitch change on the time axis(時間軸のスライド/ピッチの変更)!
I truly sincerely thank you!
Reason: Topic split and given relevant title
Re: Japanese: Sliding Time Stretch not working in Audacity 2.3.0
Post by steve » Sat Dec 01, 2018 2:53 pm
In Audacity 2.3.0, the name of this effect was changed from "Sliding Time Stretch / Pitch Shift", to "Sliding Stretch".
I think what has happened is that your effects menu has not updated correctly for this change.
Try opening the Effect Manager (https://manual.audacityteam.org/man/man ... yzers.html) and ensure that "Sliding Stretch" is enabled and "Sliding Time Stretch / Pitch Shift" is disabled.
