~/Library/Application Support/audacity/Plug-Ins [SOLVED]
Help for Audacity on macOS.
Rob351
Post by Rob351 » Mon Nov 26, 2018 9:22 pm
Hi Folks,
I downloaded Audacity 2.3.0 for Mac. I really need a noise gate, so I attempted to download and install the Nyquist noise gate. First, the directory ~/Library/Application Support/audacity/Plug-Ins was not created during the installation. Second, after manually creating the directory and moving the plug-in file there, the plug-in manager couldn't fine it. What is going on?
Regards,
Rob
billw58
Re: ~/Library/Application Support/audacity/Plug-Ins
Post by billw58 » Tue Nov 27, 2018 3:31 am
Are you sure you went to ~/Library/Application Support/audacity and not /Library/Application Support/audacity. There is a difference. If you have no audacity folder in Application Support/ after launching Audacity, you are probably looking in the wrong place.
-- Bill
Post by kozikowski » Tue Nov 27, 2018 3:40 am
That tiny squiggly line (~) at the front of the address is a big deal. It has special meaning to Macs and Linux.
Rob351
Post by Rob351 » Tue Nov 27, 2018 5:29 pm
Hi Guys,
I have it in the correct folder, but there are a couple of more issues: 1) My Mac insists on keeping a "txt" extension to the filename, so it appears as "Noisegate.ny.txt"; 2) Other plug-ins seem to be on the path "/Applications/Audacity.app/Contents/plug-ins", so I'm wondering if the path in the instructions is wrong.
FYI, I'm planning a migration to Linux, so now may be the time.
Rob351
Post by Rob351 » Tue Nov 27, 2018 5:32 pm
-- Bill
Thanks! You are right! I forgot that and stumbled into the wrong path. I've corrected that and put the file in the specified folder. But, I still can't get Audacity to load it.
Rob351
Post by Rob351 » Tue Nov 27, 2018 5:33 pm
Thanks! Very true! I'm just a bit rusty on my Unix/BSD/Linux path usage.
Post by steve » Tue Nov 27, 2018 6:47 pm
Thank Apple for that :evil:
The filename for a Nyquist plug-in MUST end in exactly ".ny". If it ends in ".ny.txt" then it will not work.
Rob351
Re: ~/Library/Application Support/audacity/Plug-Ins [SOLVED]
Post by Rob351 » Tue Nov 27, 2018 10:45 pm
I got it working, Thanks for the help! I was finally able to remove the "txt" extension by right-clicking on the filename in Finder and removing the "txt" by selecting "Get Info" and changing the filename in the info box.
