2.3.0 has lost keyboard input on dialog boxes
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
jarome
Post by jarome » Wed Nov 07, 2018 2:55 pm
On my Mac (Mojave) when audacity wants to change a file name because of illegal characters, it pops up a box with the suggested new name. Previous versions allowed you to hit return to accept the new name. Now it only responds to mouse clicks. This is very difficult and time consuming because the pop-up boxes change size, and it is easy to click cancel by accident, which causes that track to be skipped. On a project with 30 or so tracks, this has really become a chore!
And I reported another bug a long time ago, and it has not been fixed. If you hit command B to add a label, and then go to a different program to say, copy the label contents. If you then return to Audacity by right-clicking the label box, Audacity crashes every time.
waxcylinder
Re: 2.3.0 has lost keyboard input on dialog boxes
Post by waxcylinder » Wed Nov 07, 2018 3:19 pm
Testing on 2.3.0 with macOS 10.14.1 confirms that this is indeed the case - and testing on 2.2.2 shows that it works there.
So I will log this as a regression bug.
I cannot reproduce this on my Macbook with Audacity 2.3.0
Can you provide some precise steps for this?
waxcylinder
Post by waxcylinder » Wed Nov 07, 2018 3:31 pm
Logged as P2 #2027: bug https://bugzilla.audacityteam.org/show_bug.cgi?id=2027
Thanks for the report - much appreciated jarome :)
Peter.
jarome
Post by jarome » Wed Nov 07, 2018 4:06 pm
First right-click the label box. then left-click it. It crashes. See attached report
Audacity_dbgrpt-25145-20181107T110126.zip
(13.44 KiB) Downloaded 5 times
waxcylinder
Post by waxcylinder » Wed Nov 07, 2018 5:56 pm
OOH yes - I can now create this with just the right click on 2.3.0 - and on earlier Audacity versions
I'll be logging this as a P1 bug due to the crash (Audacity should not crash!)
Many thanks for the report jarome 8-)
Peter
waxcylinder
Post by waxcylinder » Wed Nov 07, 2018 6:06 pm
Logged as P1 bug #2028 https://bugzilla.audacityteam.org/show_bug.cgi?id=2028
P1 means that we cannot make the next release without fixing this :geek:
One again many thanks for the report jarome
Peter
jarome
Post by jarome » Wed Nov 07, 2018 7:46 pm
After a crash, I also get a message that there was a problem recovering my project, but it is always OK.
waxcylinder
Post by waxcylinder » Wed Nov 07, 2018 11:09 pm
Yes, crash recovery seems to work very well these days :)
Peter
waxcylinder
Post by waxcylinder » Mon Dec 03, 2018 12:26 pm
Hi jarome,
we have fixed the crashing issue for the upcoming 2.3.1, but we have a residual bug wherby on returning to the label and right clicking no context menu appears (but at least there is no crash).
The simple workaround is to left click in the label first and then you can right click to get the context menu
Original (closed) bug: https://bugzilla.audacityteam.org/show_bug.cgi?id=2028
New residual bug: https://bugzilla.audacityteam.org/show_bug.cgi?id=2044
And right now we are totally baffled as to why the context menu fails to appear. But it only appears to affect Mojave and not Sierra or High Sierra.
Peter
jarome
Post by jarome » Mon Dec 03, 2018 2:16 pm
The dialog box bug is even more important to me. When you are labeling something with many tracks, it is very tricky and time-consuming to avoid hitting the cancel button by accident when tracks need to be renamed because the dialog box changes width. And frankly, there should be an option to not display these rename dialogs, but to just accept the renames. And also, the auto rename does not if there is more than one illegal character, e.g., two colons.
