Using LAME
Help for Audacity on macOS.
audmac
Using LAME
Post by audmac » Sun Nov 04, 2018 12:53 pm
I have Aud 2.3.0 and LAME on OS 14.
I have a valoin Cassette to MP3 Converter connected, and the instructions say to click the Record button in Aud, after I start the tape, but I cannot see the Record button in Aud.
Am I missing something?
Thanks.
Mac
Re: Using LAME
Post by steve » Sun Nov 04, 2018 3:08 pm
Does Audacity look like the big picture on the front page of the manual: https://manual.audacityteam.org/
Note that the picture is interactive. If you hover your mouse over the big square button with the red dot, you will see a "tool tip" appear that says "Record Button". If you click on the image, it will take you to the section of the manual that relates to what you clicked on.
aajax
Re: Using LAME
Post by aajax » Thu Nov 08, 2018 9:47 pm
What is LAME, exactly?
Re: Using LAME
Post by steve » Thu Nov 08, 2018 10:08 pm
It is what Audacity uses for encoding audio to MP3 format.
Unless you need to create MP3 files, it is not required.
If you do want to create MP3 files with Audacity, then it is required.
See: https://manual.audacityteam.org/man/faq ... .html#lame
