Noise reduction
Noise reduction
Can I eliminate some background noise on live recording?
Reason: Given more relevant title
Re: Noise reduction
It depends on the kind of background noise, and how loud the background noise is. See: https://manual.audacityteam.org/man/noi ... ction.html
Re: Noise reduction
Audacity will only do it later. Audacity doesn't do anything in real time. If you need real time processing, some recorders and most smartphones have the ability to live record with voice processing, echo suppression and noise reduction...on live recording?
Of course, then your show is going to sound like a cellphone. Environment processing is what does that.
Good live field recording is not for the easily frightened.
Re: Noise reduction
Here's one a bit more modern. That's from one of the Matt and Tom videos. They're literally on the park bench but the voices are terrific and perfectly clear because they're using a radio-connected shotgun microphone with a dead cat windscreen. That's probably $2000 USD right there—that Matt's holding with one finger!
