I have updated to version 2.3.0 on my 2015 macbookPro running High Sierra 10.13.5 and I when I open the program the toolbar seems to all load at the center of the screen and does not move with the audacity window. I am attaching a screenshot:
That looks bad, but hopefully it’s not as bad as it looks.
- Ensure that Audacity is completely shut down (reboot the computer if necessary, but ensure that Audacity is totally closed)
- Select and copy this next line to your clipboard (Command + C):
~/Library/Application Support/audacity/ - Open “Finder”
- Click on the “Go” menu, and choose “Go to Folder”
- Right click and “Paste” (or Command + V)
- Delete these three files:
- audacity.cfg
- pluginregistry.cfg
- pluginsettings.cfg
- Launch Audacity
Audacity should now launch correctly.
wow simple, thanks!
