Editing individual tracks
Help for Audacity on macOS.
Dabell43
Post by Dabell43 » Fri Aug 17, 2018 11:17 pm
I have a stereo recording in which I'd like to vary the levels of one track only. Is there a way to do this? I only seem to be able to select both tracks. It's probably in the manual, though I haven't come across it.
Alan
Audacity 2.0.2
Mac OS 10.13.6
Re: Editing individual tracks
Post by steve » Fri Aug 17, 2018 11:56 pm
Split the track, apply the effects that you require to the two new single channel tracks, then join the tracks back together into a stereo track. See: https://manual.audacityteam.org/man/spl ... racks.html
Dabell43
Post by Dabell43 » Sat Aug 18, 2018 5:32 pm
Thank you! Exactly what I wanted.
AB
