Edit individual stereo track
Help for Audacity on macOS.
Dabell43
Post by Dabell43 » Thu Aug 16, 2018 12:22 am
The recording I imported is unbalanced, and I wish to increase the level on track 1 to match track 2. I don't see if there's a way to select only 1 of the 2 tracks to edit. Is this possible?
Audacity 2.0.3
MacOS 10.13.6
Re: Edit individual stereo track
Post by kozikowski » Thu Aug 16, 2018 2:11 am
Yes.
There is a drop-down menu to the left of the track. Split Stereo track. Use that one of the two if you intend to jam them back together later.
When you're done, Select the top track > Menu > Make Stereo Track.
