Silent gaps
Help for Audacity on macOS.
new Aud user
Silent gaps
Post by new Aud user » Wed Jul 04, 2018 4:58 pm
An audio file has a lot of silent gaps that look like straight lines as shown. What are these? Thank you.
MacOS High Sierra v.10.13.5 (17F77); Audacity v.2.2.2
Trebor
Re: Silent gaps
Post by Trebor » Wed Jul 04, 2018 5:52 pm
new Aud user
Re: Silent gaps
Post by new Aud user » Wed Jul 04, 2018 7:28 pm
skips, a/k/a dropouts, see ...
https://manual.audacityteam.org/man/faq ... oting.html
Thank you. Is this link also for help with the audio file if it was imported from a CD?
Trebor
Re: Silent gaps
Post by Trebor » Wed Jul 04, 2018 8:50 pm
... audio file if it was imported from a CD?
I've never used a Mac to import tracks from a CD, apparently it's easier than on Windows, see ...
https: //manual.audacityteam.org/man/tutorial_how_to_import_cds.html
