Now you know why critical separate-sound video productions occasionally put clapboards at the front and the back of a shoot.
"CAMERA MARK" [bang]
ACTION!!
acting.
acting.
acting.
acting.
Cut!!
"TAIL MARKER!" (holding board upside down)[bang]
The video people are looking for the picture of the zebra stripes closing and the sound people are listening for the noise.
UPDATED Audio video synch mysteries
audio_pete
Re: Audio video synch mysteries
Seems to be on right track (when have I heard that before)
new Change Speed much improved
automatically detects end of file check
shows length in multiple formats check
shows length in h:mm:ss + PAL frames check
eyeball on Filmora target
00:22:19 06
starting position of audio
00:23:19 04
took 5 tries to get to
00:22:19 03
3 frames difference
Tried in filmora
closer but still needs work
Will find a better mouth movement
that can pin down closer in Filmora
then
get audio to match to the PAL frame
Will let you know.
Thanks for getting me this far.
00:22:19 06
00:23:19 04
00:22:19 03
3 frames difference
Tried in filmora
then
Will let you know.
Nobody wrote anywhere that the error has to be constant over the course of the show. All these corrections are based on everything working normally and according to spec. You know you're in trouble when the two ends match...but not the middle. That's a maintenance or new equipment purchase problem.
audio_pete
End of round 2
One of us won by TKO
not sure if it is me or the movie.
Audacity seemed to work as advertised, at least the latest version. 2.0.2 was little / no help.
Using Filmora identified scene
00:17:34 +16 PAL frames back of head
00:17:34 + 17 PAL frames men facing speaking
That was my target
VOB_denoise into Audacity was 00:31:27 +14 PAL
(fog of war aside: just checked the VOB opened in Audacity just now was 00:30:10 + 7 PAL
not sure why the difference but was 2.0.2 vs 2.2.2)
Working with 00:31:27 + 14 PAL length
Took 10 tries to get "men facing speaking"
down to 00:17:34 +17 matching my video mark
00:30:08 +7 PAL frames was just a bit short
00:30:08 + 6 PAL frames was just a bit too long
settled on 00:30:08 +7 PAL frames as giving the best match
BUT
took a lot of work for a queasy result
I don't think I ever watched peoples mouths so much
the film, at least my copy, was dark and mostly shot from a distance
I guess its just queasy because I "know" it is not "exact".
AND this is VOB 1 of 1 DVD, a 1 gig VOB2, and much shorter VOB 3 await
NOT to mention converting the last 2 hours of the film (1 more DVD).
I might go back to Playboy of the Western World because I like it so much
but I think Richard III and Twelfth Night will have to wait.
Thanks for the attention and help.
Plan to drop a donation in the basket when the plate comes round.
That was my target
BUT
That's the curse, isn't it? I can't watch bad editing on YouTube. It makes my teeth hurt.I don't think I ever watched peoples mouths so much
