Reseting EQ levels?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
coachlamb
Operating System: OS X 10.10 Yosemite
Reseting EQ levels?
Post by coachlamb » Fri Jun 08, 2018 7:55 pm
While playing back an edited podcast (that I had already done EQ and compression on), we noticed an imperfection in the editing. I am attempting to splice in a portion of the raw, unedited recording, but I can't get the sound to come out the same as the previously edited portion. Is there any way to "reset" the track to a baseline so I can get this to sound seamless?
Trebor
Re: Reseting EQ levels?
Post by Trebor » Sat Jun 09, 2018 12:07 am
There is a plugin to match the frequency-response of one track to another
It's complicated though, see ... viewtopic.php?p=334806#p334806
