Rendering to one track when there's overlap?
Help for Audacity 2.x.x on Mac OS X.
ImageThis forum is for Audacity 2.x.x on Mac OS X 10.4 and later.
chrishecht
Post by chrishecht » Mon Jun 04, 2018 11:15 pm
Aloha,
Apologies in advance, but my search didn't produce an answer to this noob question.
I use Audacity in post, after recording live music. Sometimes, I have a few segments of the recording, broken between songs during applouse. each segment a different pair of stereo tracks.
I like to crossfade between the segments/tracks, so they overlap in time just a little. I'd like to render down to one stereo pair, but I don't get all the tracks when I do.
So far, the only way I've found to do this is to export, leading me to believe I'm ignorant of correct use of Audacity's featueres.
Can anyone offer guidance?
TIA
billw58
Re: Rendering to one track when there's overlap?
Post by billw58 » Mon Jun 04, 2018 11:47 pm
Assuming you are using Tracks > Mix > Mix and Render, that command mixes only the selected tracks.
-- Bill
chrishecht
Post by chrishecht » Mon Jun 04, 2018 11:49 pm
Pardon typos, and:
Using Audacity 2.2.2 on MacOS 10.13.4
chrishecht
Post by chrishecht » Tue Jun 05, 2018 12:35 am
billw58 wrote:Assuming you are using Tracks > Mix > Mix and Render, that command mixes only the selected tracks.
-- Bill
Yes, using that command, must not have selected all tracks. D'oh.
Appreciate your help!
