"Error Opening Sound Device"
Help for Audacity on macOS.
AltonDex
Post by AltonDex » Sun May 27, 2018 2:01 am
Audacity 2.2.2
MacOs High Sierra 10.13.4
Hello, every time I hit record message in the subject line comes up, as well as "change audio host, recording device, and the recording sample rate." I think I recall that there is only partial support for MacOS Sierra. If this is so and there is no fix, guess I will be returning this Cassette to MP3 gadget, unless you know of another fix or app to complete this action.
Thanks in advance for any help,
Alton Dex.
waxcylinder
Re: "Error Opening Sound Device"
Post by waxcylinder » Sun May 27, 2018 10:13 am
See this page in the Audacity Manual about the error: https://manual.audacityteam.org/man/err ... evice.html
But there is full support for macOS Sierra/High Sierra - a couple of Audacity releases ago Audacity was listed as partial support for Sierra - but it always ran fine on my macbook pro with Sierra and High Sierra.
These days i#I am running Audacity 2.2.2 and 2.3.0 alpha test on High Sierra 10.13.3 and 10.13.4 and it runs just fine.
