Pitch change
david22
Pitch change
Post by david22 » Sat May 12, 2018 5:39 pm
When playing back clips the pitch has changed. I have not recorded in several weeks when playing back recordings was fine. During that time I did receive a Windows update. Though I have restored my system back to before the updates were installed, I still have this problem. I was using 2.2.2 Beta. I tried installing 2.1.2, same problem. System is Windows 10. Any ideas?
DVDdoug
Forum Crew
Re: Pitch change
Post by DVDdoug » Sat May 12, 2018 7:50 pm
How far off is it?
Are you using any hardware other than your regular soundcard? Are you using a USB microphone?
david22
Re: Pitch change
Post by david22 » Sat May 12, 2018 9:23 pm
Pitch drops a half step. I'm using M-Track 8 from M-Audio for recording. Playing back goes through the sound card in my laptop. It's been that way for years with no problem. But now we have problems. Why?
david22
Re: Pitch change
Post by david22 » Sat May 12, 2018 9:24 pm
No USB microphone. Though my M-Track-8 is a USB connection.
DVDdoug
Forum Crew
Re: Pitch change
Post by DVDdoug » Sat May 12, 2018 9:48 pm
That could be it... The clock (oscillator) in your soundcard may be off. No clock is perfect but "cheap consumer soundcards" can be off enough for a musician to notice. And, you'll never see a problem if record & playback with the same "bad" soundcard.
Try playing-back through your USB interface.
I have no explanation for that and a Windows update shouldn't cause a the hardware clock to change.
david22
Re: Pitch change
Post by david22 » Sat May 12, 2018 10:59 pm
Okay...I have both record and playback going through the M-Track 8 and still the same problem. The playback pitch is 1/2 step lower than what was recorded. Actually I can't tell if it the play back that's playing 1/2 step lower or if it was recorded that way.
Also, I failed to mention before, when I try overdubbing onto another track (recording along with an existing tack playing back) I get dropouts all over the place.
What in the world is going on?
Re: Pitch change
Post by steve » Sun May 13, 2018 12:46 pm
Launch Audacity and import one of those recordings, then look at the "Project Rate" in the lower left corner of the main Audacity window. What does it say?
