Zooming.
Zooming.
The question is, if I clicked on the plus horizontally (horizontal zooming), then a few more times on the plus, is it possible to return just one key, as it was, that is right after import, the whole track on one page? Ctrl+2 doesn't return. That is, the imported track is the entire width of the page, as the default. And several times I clicked on the plus, the view changed, and in order to return the original, I need to remember how many times there was a plus - and so many times to push the minus. Can not be a single key?
Re: Zooming.
"Ctrl + F"
See also: http://manual.audacityteam.org/man/zooming.html
Re: Zooming.
Thank you!
Re: Zooming.
And is there a key that would immediately put as it were on the maximum plus, that is, "plus" can not be pressed more?
waxcylinder
Re: Zooming.
Yes there is now in 2.2.2 where we added the Zoom toggle button in the Edit Toolbar: https://manual.audacityteam.org/man/new ... .html#zoom
But you will need to reset a preference to get one of the two toggles to be max zoom
Go to Edit > Preferences and choose the Tracks entry
In there you will see the Zoom Toggle with two drop-downs - I would suggest resetting the second of the two Preset2 - in its dropdown menu select MaxZoom and then press the OK button
You will then be able to use the Zoom Toggle to toggle between Normal zoom and Max zoom - and the Zoom Toggle does have a default shortcut assigned Shift+Z
Re: Zooming.
Thank you! Even there is a button "Zoom toggle" in the top row, 2 magnifiers.
