...No Sound
ethan417
...No Sound
Post by ethan417 » Tue Apr 17, 2018 2:48 pm
Hi
I imported an MP3 file that I want to insert labels in so that I can dived this one long track into separate segments.
All was going nicely but I did not have time to complete entering the labels.
I saved the project.
This morning when I opened the project - everything was as I left it.
But - I don't hear any sound when playing that particular track.
In fact I don't have sound in any project that I open in Audacity
Sound works for all other applications.
Thanks for your help.
DVDdoug
Forum Crew
Re: ...No Sound
Post by DVDdoug » Tue Apr 17, 2018 3:33 pm
Make sure you've got the correct Playback Device selected.
Do you have a USB mic or USB turntable plugged-in? ...Sometimes Windows with switch to whatever audio device was plugged-in last, even if that device is only for recording.
