I have downloaded Audacity 2.2.2, and notice that I cannot add label text after creating a label at the playback position. While recording, I press Ctrl + M, which inserts a new blank label at the playback position. In prior versions, I could immediately enter the label text, then press Enter. That does not happen anymore. After pressing Ctrl + M, the label is created, but I need to click in the label in order to enter text.
Ctrl + B (label at current position) works as it always has, the label is created and is in edit mode, to accept a text entry. This is how I wish for Ctrl + M to work also.
Is there a setting that I can change, in order to get this to work?
Label at Playback Position - cannot enter label text
Re: Label at Playback Position - cannot enter label text
Unfortunately it is a bug rather than a setting. It has been fixed in the development code, so the next release will have the fix.
I am a newcomer to Audacity. Are updates issued frequently. Is it fair to expect a new release within the short term, or should I install 2.2.1 (where I know this feature works)?
Updates have been a lot more frequent recently, but the next update is a big one (version 2.3.0), so it'll be a few months before it's released.
If you can just work around the label problem for a few months, then that's probably the best thing to do.
Please be very careful if you decide to use Audacity 2.2.1 - it has this known bug in it (I think this also applies to Audacity 2.2.0): viewtopic.php?f=46&t=99026
waxcylinder
I think this bug was introduced in 2.2.1 ad remains in 2.2.2 - and is fixed for the upcoming 2.3.0steve wrote:Please be very careful if you decide to use Audacity 2.2.1 - it has this known bug in it (I think this also applies to Audacity 2.2.0): viewtopic.php?f=46&t=99026
I do not believe that 2.2.0 has that bug.
There are two bugs that we are talking about.waxcylinder wrote:I think this bug was introduced in 2.2.1 ad remains in 2.2.2 - and is fixed for the upcoming 2.3.0steve wrote:Please be very careful if you decide to use Audacity 2.2.1 - it has this known bug in it (I think this also applies to Audacity 2.2.0): viewtopic.php?f=46&t=99026
The "label" bug exists in 2.2.2 (and possibly some version before) and will be fixed in the next release (2.3.0)
The bug that loses data when overwriting a project with "Save As" is already fixed in 2.2.2, but present in 2.2.1 (and possibly earlier). This was a more serious bug because it could totally destroy a project, which is why I urge great caution (or better still, don't use 2.2.1).
