How to export audio with Silences?
Re: How to export audio with Silences?
Post by steve » Thu Apr 05, 2018 10:36 am
belladaisy2018 wrote:How do I export stems with the correct lengths of silence at the beginning?
Unfortunately Audacity does not have a built-in option for this, but there is an easy workaround.
For all tracks that start after time=0, select a section of the empty space, starting at time=0
(more about selecting audio here: http://manual.audacityteam.org/man/auda ... ction.html)
Then use "Generate menu > Silence" to generate silence into the selections
The tracks will now be exported from time=0 (because they start at time=0)
Trebor
Post by Trebor » Thu Apr 05, 2018 10:42 am
The workaround is to add silence (or a short bleep) to all the tracks ...
Select all the tracks,("Ctrl"+"A"), move the cursor to the start, ("J"), then generate, say 0.1 seconds of silence, or a short bleep.
Post by kozikowski » Thu Apr 05, 2018 4:10 pm
You can also create one long silent track starting at 0 and export that plus the target track. Audacity will mix them at export.
Post by steve » Thu Apr 05, 2018 4:20 pm
kozikowski wrote:You can also create one long silent track starting at 0 and export that plus the target track. Audacity will mix them at export.
That's OK when exporting a single track, but not a solution when using "Export Multiple" based on tracks.
waxcylinder
Post by waxcylinder » Thu Apr 05, 2018 4:48 pm
So is this a bug - or is it intentional "by design" ?
Peter
Post by steve » Thu Apr 05, 2018 5:15 pm
It's "by design" (but not a good design).
I don't think there is opposition to it being redesigned better ;)
Post by kozikowski » Thu Apr 05, 2018 5:47 pm
The export doesn’t match the timeline graphics or the timeline playback. That’s an unfortunate feature.
Post by kozikowski » Thu Apr 05, 2018 5:58 pm
I like the single silent track approach because it lets me change my mind and move a track. If I do move with the other solutions, I have to remove the “fake silence,” and I can’t depend on UNDO. I can’t just shove left because Audacity will complain about “sound before zero.”
waxcylinder
Post by waxcylinder » Fri Apr 06, 2018 2:12 pm
steve wrote:It's "by design" (but not a good design).
I seems to me that empty space before the audio should be treated as silence on export and mixing.
If the user has their audio starting at T=20 seconds with blank before it would seem to me that they want the audio to start at T-20 and not T=0
We could, of course, add a preference for this - but the default would have to be: Treat leading blank as silence = "on"
But personally I think a preference is overkill.
If a user has audio starting at T=20 and the want it to start at T=0, then they can easily shift it back with the Time-shift tool.
I do note that we have this longstanding ednote in the Manual on the Mixing page:
Gale 07Dec11: ToDo-2 There is no mention here or in Tracks Menu of how render handles white space before the audio begins or audio before zero. Should there be? Current behavior following r11248 is to preserve the clip length by no longer rendering white space between time zero and first audio as silence, and to preserve audio before time zero instead of discarding it. So people who want to export tracks with silent lead-ins preserved now have to generate silence after rendering. I think that tip at least should be in this page.
Users should not be forced into the kludgy solutions/workarounds given earlier in this thread to maintain the proper start times of their audio clips.
Oh and by the way empty space between sections of audio should also be treated as silence for export/mixing.
So do we need to log this on Bugzilla - or maybe write a short proposal - or is this a bit of "bad design" that we can just fix?
Peter
