Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
waxcylinder
Post
by waxcylinder » Tue Mar 27, 2018 4:13 pm
MaxFlight wrote:Yea! The team doesn't fool around when it comes to getting things done, it seems. Thank you!
hahaha - don't get too used to it - it's not always like that
waxcylinder
Post
by waxcylinder » Wed Mar 28, 2018 4:16 pm
And I've tested this today on my Mac and it works just fine and dandy.
Also you'll probably be please to know that the default for the half-size is "off" - so by default you get both halves of the waveform in a collapsed track.
CharlieSummers
Post
by CharlieSummers » Tue Jul 31, 2018 6:57 pm
Anyone know in what version this default started? Not interested in bleeding-edge 2.3 (I use it for work, not play, so if it's higher than front-page I don't want it), and really despise the half wave view of collapsed tracks (all of the tracks I'm not working with at the moment are collapsed). I really want to back-step to a version that doesn't default to this.
This is why I should know better than to upgrade open-source that ain't broken...
waxcylinder
Post
by waxcylinder » Tue Jul 31, 2018 7:47 pm
Stick with the released 2.2.2 for now and go to Edit > Preferences choose the Tracks tab then and uncheck Use half-wave display when collapsed - hey presto: you get full collapsed waves ...
And BTW the upcoming 2.3.0 is pretty near to release now and not much is different just some cool new stuff added.
