hi when I record 78s theres always a little noise after the tune is finished..using audacity how do I revoe it without making the end too short?
lenny
A QUESTION ABOUT RECORDING..
Re: A QUESTION ABOUT RECORDING..
You can use Effect -> Fade Out and/or select the part you want silenced and Generate -> Silence.
waxcylinder
This suggested workflow in the Audacity Manual may be useful to you: https://manual.audacityteam.org/man/rec ... cords.html
