"Missing audio datablock files" when opening save file
shadowsn4ke
I was working on an important project when my audacity stopped responding. "This is ok, I've saved it anyways," I think to myself. I recover the project and get this error message (see attached image *helpme1*) ((yes its a despacito remix but its satire)) I haven't moved or touched anything and after I select silence for current session ((which makes almost everything silent)) I get this popup (see *helpme2*) it says there are 11000 files missing but in the folder they're all there and it asks for the orphan files. It seems to me that it's branded the project files as unimportant ones. I've tried audacity recovery tool and I just get an error, and there too many files to do by hand. Please help I've spent hours on this thanks.
- Attachments
- helpme1.png (14.01 KiB) Viewed 218 times
- helpme2.png (12.46 KiB) Viewed 218 times
- hrlpme3.png (53.2 KiB) Viewed 218 times
- helpme4.png (16.06 KiB) Viewed 218 times
waxcylinder
Re: "Missing audio datablock files" when opening save file
Are you using Audacity 2.2.0 or 2.2.1 ?
And if so are you using "Save As" instead of "Save" yto save your existing open project ?
shadowsn4ke
version 2.1.3waxcylinder wrote:Are you using Audacity 2.2.0 or 2.2.1 ?
