Hi,
I have installed the latest Audacity, but at the end of the installation I receive this error message: IPersistFile Save Failed:: Code 0x80070002
I have checked for viruses and malware and none show up. I uninstalled an older version of Audacity first and installed the latest version as Administrator. I still received the error message. I uninstalled Audacity again and downloaded the zip file and installed again, but still the same error message.
Can someone give some ideas on how to fix this, please? I have Windows 10 installed.
The error code indicates that Windows is unable to find the file specified, and it usually associated with either a Windows update or Windows backup.
There are many reasons why the problem can occur, including disk failure, a disk being mounted incorrectly, incorrect profile data in the registry, Windows is trying to copy a file that has been deleted or corrupted, or many other reasons. The full error message will generally include information to narrow down the cause of the error.
